Ana içeriğe geç
Motorola Xoom Wifi Back-Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: adım 1, 2 resimden 1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: adım 1, 2 resimden 2.
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 2, 2 resimden 1. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 2, 2 resimden 2.
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 3, 3 resimden 1. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 3, 3 resimden 2. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 3, 3 resimden 3.
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: adım 4, 2 resimden 1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: adım 4, 2 resimden 2.
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  5. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 5, 2 resimden 1. Motorola Xoom Wifi Back-Facing Camera Replacement: adım 5, 2 resimden 2.
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Mercier
532 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G39
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 389
