Ana içeriğe geç
Motorola Xoom Wifi Display Assembly Replacement
Neye ihtiyacın var
  1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: adım 1, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: adım 1, 2 resimden 2.
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Xoom Wifi Display Assembly Replacement: adım 2, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 2, 2 resimden 2.
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Xoom Wifi Display Assembly Replacement: adım 3, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 3, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 3, 3 resimden 3.
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Xoom Wifi Display Assembly Replacement, Battery: adım 4, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Xoom Wifi Display Assembly Replacement: adım 5, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 5, 2 resimden 2.
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Xoom Wifi Display Assembly Replacement, Speakers: adım 6, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Speakers: adım 6, 2 resimden 2.
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: adım 7, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: adım 7, 2 resimden 2.
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola Xoom Wifi Display Assembly Replacement: adım 8, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 8, 2 resimden 2.
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: adım 9, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: adım 9, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: adım 9, 3 resimden 3.
    • Take a plastic opening tool and carefully pry off the touch screen controller connection.
    • Be careful with the black cover under the connection.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola Xoom Wifi Display Assembly Replacement: adım 10, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 10, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 10, 3 resimden 3.
    • There are two relay wires that must be disconnected.
    • Pull both relay wires out of their connection ports.
    • Make sure to flip up the small black tab before you pull out the wire.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola Xoom Wifi Display Assembly Replacement: adım 11, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 11, 2 resimden 2.
    • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  12. Motorola Xoom Wifi Display Assembly Replacement: adım 12, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 12, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 12, 3 resimden 3.
    • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
    • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
    • Motherboard should lift out easily and completely.
    FixBot'a Sor
    Yorum Ekle
  13. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: adım 13, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: adım 13, 2 resimden 2.
    • Using the T-6 Torx screwdriver, unscrew the 17 4mm screws along the edge of the screen frame.
    FixBot'a Sor
    Yorum Ekle
  14. Motorola Xoom Wifi Display Assembly Replacement: adım 14, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 14, 2 resimden 2.
    • Take the small plastic opening tool and separate the front glass from the screen frame.
    • Unfold the glass and the frame flat on the table.
    FixBot'a Sor
    Yorum Ekle
  15. Motorola Xoom Wifi Display Assembly Replacement: adım 15, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 15, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 15, 3 resimden 3.
    • Using the T-5 Torx screwdriver, unscrew the 12 4.1mm screws along the edge of the screen.
    • Pull ribbon wire out of slot in the frame to pull the screen off of the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Andrew Mercier
532 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G39
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 2,005
