Ana içeriğe geç
Motorola Xoom Wifi Display Assembly Replacement
Neye ihtiyacın var
  1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: adım 1, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: adım 1, 2 resimden 2.
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Display Assembly Replacement: adım 2, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 2, 2 resimden 2.
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Display Assembly Replacement: adım 3, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 3, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 3, 3 resimden 3.
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Display Assembly Replacement, Battery: adım 4, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Display Assembly Replacement: adım 5, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 5, 2 resimden 2.
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
  6. Motorola Xoom Wifi Display Assembly Replacement, Speakers: adım 6, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Speakers: adım 6, 2 resimden 2.
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
  7. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: adım 7, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: adım 7, 2 resimden 2.
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  8. Motorola Xoom Wifi Display Assembly Replacement: adım 8, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 8, 2 resimden 2.
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
  9. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: adım 9, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: adım 9, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: adım 9, 3 resimden 3.
    • Take a plastic opening tool and carefully pry off the touch screen controller connection.
    • Be careful with the black cover under the connection.
  10. Motorola Xoom Wifi Display Assembly Replacement: adım 10, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 10, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 10, 3 resimden 3.
    • There are two relay wires that must be disconnected.
    • Pull both relay wires out of their connection ports.
    • Make sure to flip up the small black tab before you pull out the wire.
  11. Motorola Xoom Wifi Display Assembly Replacement: adım 11, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 11, 2 resimden 2.
    • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
  12. Motorola Xoom Wifi Display Assembly Replacement: adım 12, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 12, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 12, 3 resimden 3.
    • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
    • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
    • Motherboard should lift out easily and completely.
  13. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: adım 13, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: adım 13, 2 resimden 2.
    • Using the T-6 Torx screwdriver, unscrew the 17 4mm screws along the edge of the screen frame.
  14. Motorola Xoom Wifi Display Assembly Replacement: adım 14, 2 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 14, 2 resimden 2.
    • Take the small plastic opening tool and separate the front glass from the screen frame.
    • Unfold the glass and the frame flat on the table.
  15. Motorola Xoom Wifi Display Assembly Replacement: adım 15, 3 resimden 1. Motorola Xoom Wifi Display Assembly Replacement: adım 15, 3 resimden 2. Motorola Xoom Wifi Display Assembly Replacement: adım 15, 3 resimden 3.
    • Using the T-5 Torx screwdriver, unscrew the 12 4.1mm screws along the edge of the screen.
    • Pull ribbon wire out of slot in the frame to pull the screen off of the frame.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Andrew Mercier
532 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G39
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,587
