Ana içeriğe geç
Motorola i1000plus Back Cover Replacement
Neye ihtiyacın var
  1. Motorola i1000plus Back Cover Replacement, Battery: adım 1, 3 resimden 1. Motorola i1000plus Back Cover Replacement, Battery: adım 1, 3 resimden 2. Motorola i1000plus Back Cover Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: adım 2, 3 resimden 1. Motorola i1000plus Back Cover Replacement, Antenna: adım 2, 3 resimden 2. Motorola i1000plus Back Cover Replacement, Antenna: adım 2, 3 resimden 3.
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: adım 3, 3 resimden 1. Motorola i1000plus Back Cover Replacement, Back Cover: adım 3, 3 resimden 2. Motorola i1000plus Back Cover Replacement, Back Cover: adım 3, 3 resimden 3.
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: adım 4, 1 resimden 1.
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: adım 5, 1 resimden 1.
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: adım 6, 3 resimden 1. Motorola i1000plus Back Cover Replacement: adım 6, 3 resimden 2. Motorola i1000plus Back Cover Replacement: adım 6, 3 resimden 3.
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Sonuç
Austin Lake
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-3, Benson Fall 2013 Clemson, Team 13-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G3
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 210
