Ana içeriğe geç
Motorola i1000plus Motherboard Replacement
Neye ihtiyacın var
  1. Motorola i1000plus Motherboard Replacement, Battery: adım 1, 3 resimden 1. Motorola i1000plus Motherboard Replacement, Battery: adım 1, 3 resimden 2. Motorola i1000plus Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Motherboard Replacement, Antenna: adım 2, 3 resimden 1. Motorola i1000plus Motherboard Replacement, Antenna: adım 2, 3 resimden 2. Motorola i1000plus Motherboard Replacement, Antenna: adım 2, 3 resimden 3.
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Motherboard Replacement, Back Cover: adım 3, 3 resimden 1. Motorola i1000plus Motherboard Replacement, Back Cover: adım 3, 3 resimden 2. Motorola i1000plus Motherboard Replacement, Back Cover: adım 3, 3 resimden 3.
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Motherboard Replacement: adım 6, 3 resimden 1. Motorola i1000plus Motherboard Replacement: adım 6, 3 resimden 2. Motorola i1000plus Motherboard Replacement: adım 6, 3 resimden 3.
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
  7. Motorola i1000plus Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
    • Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
  8. Motorola i1000plus Motherboard Replacement: adım 8, 3 resimden 1. Motorola i1000plus Motherboard Replacement: adım 8, 3 resimden 2. Motorola i1000plus Motherboard Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone.
    • Do not pull the connector off by the wire. This could damage or destroy the wire or connector.
  9. Motorola i1000plus Motherboard Replacement: adım 9, 2 resimden 1. Motorola i1000plus Motherboard Replacement: adım 9, 2 resimden 2.
    • Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board.
    • Do not pull the motherboard too far away from the phone with the ribbon cable still connected. this will damage the cable or the motherboard.
  10. Motorola i1000plus Motherboard Replacement: adım 10, 2 resimden 1. Motorola i1000plus Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone.
    • Be sure to pull straight down to disconnect the ribbon cable properly. Pulling in another direction may cause damage to the cable or the motherboard.
Sonuç
Matthew Byrd
401 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-3, Benson Fall 2013 Clemson, Team 13-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S13G3
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 181
