Ana içeriğe geç
Motorola i450 Boost Mobile Antenna Replacement
Neye ihtiyacın var
  1. Motorola i450 Boost Mobile Antenna Replacement, Antenna: adım 1, 3 resimden 1. Motorola i450 Boost Mobile Antenna Replacement, Antenna: adım 1, 3 resimden 2. Motorola i450 Boost Mobile Antenna Replacement, Antenna: adım 1, 3 resimden 3.
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. Motorola i450 Boost Mobile Antenna Replacement: adım 2, 3 resimden 1. Motorola i450 Boost Mobile Antenna Replacement: adım 2, 3 resimden 2. Motorola i450 Boost Mobile Antenna Replacement: adım 2, 3 resimden 3.
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
Sonuç
Garrison Stevens
1 İtibar
6 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 388
