Ana içeriğe geç
Motorola i450 Boost Mobile Circuit Board Replacement
Neye ihtiyacın var
  1. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: adım 1, 3 resimden 1. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: adım 1, 3 resimden 2. Motorola i450 Boost Mobile Circuit Board Replacement, Back Cover: adım 1, 3 resimden 3.
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: adım 2, 3 resimden 1. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: adım 2, 3 resimden 2. Motorola i450 Boost Mobile Circuit Board Replacement, Battery: adım 2, 3 resimden 3.
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: adım 3, 2 resimden 1. Motorola i450 Boost Mobile Circuit Board Replacement, SIM Card: adım 3, 2 resimden 2.
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Circuit Board Replacement: adım 4, 3 resimden 1. Motorola i450 Boost Mobile Circuit Board Replacement: adım 4, 3 resimden 2. Motorola i450 Boost Mobile Circuit Board Replacement: adım 4, 3 resimden 3.
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Circuit Board Replacement, Circuit Board: adım 5, 1 resimden 1.
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Circuit Board Replacement: adım 6, 1 resimden 1.
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Circuit Board Replacement: adım 7, 3 resimden 1. Motorola i450 Boost Mobile Circuit Board Replacement: adım 7, 3 resimden 2. Motorola i450 Boost Mobile Circuit Board Replacement: adım 7, 3 resimden 3.
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
Sonuç
Amber King
8 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 419
