Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
The keypad protects the phone's interior while enabling the user to input commands into the phone.
  1. Place the phone on a flat surface with the front facing down. Insert your finger under the gray plastic cover at the bottom end of the phone. Lift the cover off the phone.
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Place your thumb in the notch in the lower left corner of the battery compartment. Lift the battery up and away from the phone. Remove the battery.
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Locate the metal slider that holds the SIM card in place. Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Lift the metal flap to gain access to the bottom of the SIM card. Remove the SIM card by sliding it out parallel to the bottom of the flap. Remove the SIM card by sliding it out parallel to the bottom of the flap.
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Extend the antenna.
    • Extend the antenna.
  6. Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Gently lift off the back half of the phone and set to the side. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  8. Gently lift the end of the circuit board farthest from the phone hinge. The circuit board is permanently connected to the phone casing at the end nearest to the hinge. Grasp the keypad at the bottom of the phone, raise it, and pull it away.
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
Sonuç
Garrison Stevens
1 İtibar
6 adet Kılavuz yazıldı
Takım
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S15G2
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 372
