Ana içeriğe geç
Motorola i560 Keypad Replacement
Neye ihtiyacın var
  1. Motorola i560 Keypad Replacement, Battery: adım 1, 1 resimden 1.
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola i560 Keypad Replacement: adım 2, 1 resimden 1.
    • Lift the back panel of the phone to expose battery (not shown here).
    FixBot'a Sor
    Yorum Ekle
  3. Motorola i560 Keypad Replacement, Motherboard: adım 3, 1 resimden 1.
    • Pull the antenna up to reveal two of the six screws.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola i560 Keypad Replacement: adım 4, 1 resimden 1.
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola i560 Keypad Replacement: adım 5, 2 resimden 1. Motorola i560 Keypad Replacement: adım 5, 2 resimden 2.
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola i560 Keypad Replacement: adım 6, 2 resimden 1. Motorola i560 Keypad Replacement: adım 6, 2 resimden 2.
    • Detach the first ribbon cable by unplugging it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola i560 Keypad Replacement: adım 7, 2 resimden 1. Motorola i560 Keypad Replacement: adım 7, 2 resimden 2.
    • Detach the speaker ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola i560 Keypad Replacement: adım 8, 1 resimden 1.
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola i560 Keypad Replacement, Keypad: adım 9, 1 resimden 1.
    • Push lightly from the front of the keypad to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Haley S
10 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G6
3 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 384
