Ana içeriğe geç
Motorola i560 Metal Support Plate Replacement
Neye ihtiyacın var
  1. Motorola i560 Metal Support Plate Replacement, Battery: adım 1, 1 resimden 1.
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Metal Support Plate Replacement: adım 2, 1 resimden 1.
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Metal Support Plate Replacement, Side Volume Button: adım 3, 1 resimden 1.
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Metal Support Plate Replacement: adım 4, 1 resimden 1.
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Metal Support Plate Replacement: adım 5, 2 resimden 1. Motorola i560 Metal Support Plate Replacement: adım 5, 2 resimden 2.
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Metal Support Plate Replacement: adım 6, 2 resimden 1. Motorola i560 Metal Support Plate Replacement: adım 6, 2 resimden 2.
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Metal Support Plate Replacement: adım 7, 3 resimden 1. Motorola i560 Metal Support Plate Replacement: adım 7, 3 resimden 2. Motorola i560 Metal Support Plate Replacement: adım 7, 3 resimden 3.
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Metal Support Plate Replacement, Metal Support Plate: adım 8, 3 resimden 1. Motorola i560 Metal Support Plate Replacement, Metal Support Plate: adım 8, 3 resimden 2. Motorola i560 Metal Support Plate Replacement, Metal Support Plate: adım 8, 3 resimden 3.
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
Sonuç
Haley S
10 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 123
