Ana içeriğe geç
Motorola i560 Screen Replacement
Neye ihtiyacın var
  1. Motorola i560 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Screen Replacement: adım 2, 1 resimden 1.
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Screen Replacement, Motherboard: adım 3, 1 resimden 1.
    • Pull the antenna up to reveal two of the six screws.
  4. Motorola i560 Screen Replacement: adım 4, 1 resimden 1.
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
  5. Motorola i560 Screen Replacement: adım 5, 2 resimden 1. Motorola i560 Screen Replacement: adım 5, 2 resimden 2.
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Screen Replacement: adım 6, 2 resimden 1. Motorola i560 Screen Replacement: adım 6, 2 resimden 2.
    • Detach the first ribbon cable by unplugging it from the motherboard.
  7. Motorola i560 Screen Replacement: adım 7, 2 resimden 1. Motorola i560 Screen Replacement: adım 7, 2 resimden 2.
    • Detach the speaker ribbon cable from the motherboard.
  8. Motorola i560 Screen Replacement: adım 8, 1 resimden 1.
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
  9. Motorola i560 Screen Replacement, Keypad: adım 9, 1 resimden 1.
    • Push lightly from the front of the keypad to remove it.
  10. Motorola i560 Screen Replacement, Screen: adım 10, 2 resimden 1. Motorola i560 Screen Replacement, Screen: adım 10, 2 resimden 2.
    • By applying force, "pop" the screen out of the connecting hinge frame of the phone.
  11. Motorola i560 Screen Replacement: adım 11, 2 resimden 1. Motorola i560 Screen Replacement: adım 11, 2 resimden 2.
    • Carefully slide the speaker ribbon cable through the slot in the front frame of the phone.
  12. Motorola i560 Screen Replacement: adım 12, 1 resimden 1.
    • After sliding the ribbon cable through the front frame of the phone, the separated screen and phone frame will appear as shown.
Sonuç
Ariel
19 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 165
