Ana içeriğe geç
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: adım 1, 2 resimden 1. Motorola i710 Keypad Sensor Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola i710 Keypad Sensor Replacement, Battery: adım 2, 1 resimden 1.
    • Push the battery towards the top of the phone and lift up.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: adım 3, 3 resimden 1. Motorola i710 Keypad Sensor Replacement, Motherboard: adım 3, 3 resimden 2. Motorola i710 Keypad Sensor Replacement, Motherboard: adım 3, 3 resimden 3.
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: adım 4, 2 resimden 1. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: adım 4, 2 resimden 2.
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Katelyn
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G2
4 Üyeler
41 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 628
