Ana içeriğe geç
Motorola i710 LCD Screen Replacement
Neye ihtiyacın var
  1. Motorola i710 LCD Screen Replacement, Battery Cover: adım 1, 2 resimden 1. Motorola i710 LCD Screen Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola i710 LCD Screen Replacement, Battery: adım 2, 1 resimden 1.
    • Push the battery towards the top of the phone and lift up.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola i710 LCD Screen Replacement, LCD Screen Cover: adım 3, 3 resimden 1. Motorola i710 LCD Screen Replacement, LCD Screen Cover: adım 3, 3 resimden 2. Motorola i710 LCD Screen Replacement, LCD Screen Cover: adım 3, 3 resimden 3.
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola i710 LCD Screen Replacement: adım 4, 2 resimden 1. Motorola i710 LCD Screen Replacement: adım 4, 2 resimden 2.
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola i710 LCD Screen Replacement: adım 5, 3 resimden 1. Motorola i710 LCD Screen Replacement: adım 5, 3 resimden 2. Motorola i710 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola i710 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 1. Motorola i710 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 2. Motorola i710 LCD Screen Replacement, LCD Screen: adım 6, 3 resimden 3.
    • Use a spudger to detach the ribbon cable connecting the the LCD screen to the rest of the phone.
    • The TFT LCD screen will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carson Meena
16 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G2
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 45
Her zaman: 757
