Ana içeriğe geç
Motorola i710 Microphone Replacement
Neye ihtiyacın var
  1. Motorola i710 Microphone Replacement, Battery Cover: adım 1, 2 resimden 1. Motorola i710 Microphone Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola i710 Microphone Replacement, Battery: adım 2, 1 resimden 1.
    • Push the battery towards the top of the phone and lift up.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola i710 Microphone Replacement, Back Casing: adım 3, 3 resimden 1. Motorola i710 Microphone Replacement, Back Casing: adım 3, 3 resimden 2. Motorola i710 Microphone Replacement, Back Casing: adım 3, 3 resimden 3.
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola i710 Microphone Replacement, Microphone: adım 4, 3 resimden 1. Motorola i710 Microphone Replacement, Microphone: adım 4, 3 resimden 2. Motorola i710 Microphone Replacement, Microphone: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone.
    • The microphone sits just below the keys on the front cover molding.
    • Grasp the microphone with tweezers and lift it out of the front cover.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Carson Meena
16 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G2
4 Üyeler
41 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 40
Her zaman: 641
