Giriş
Once the battery and case back cover have been removed, the motherboard can be accessed as shown in this guide.
Parçalar
Hiçbir parçaya gerek yok.
  1. Slide the cover release button towards the bottom of the phone Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Push the battery towards the top of the phone and lift up.
    • Push the battery towards the top of the phone and lift up.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other. Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
  5. Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge. Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort. The motherboard should now be completely disconnected from the phone.
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
Sonuç
Carson Meena
16 İtibar
5 adet Kılavuz yazıldı
Takım
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G2
4 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 254
