Ana içeriğe geç
Motorola i850 LCD Screen Replacement
Neye ihtiyacın var
  1. Motorola i850 LCD Screen Replacement, LCD Board: adım 1, 1 resimden 1.
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 LCD Screen Replacement: adım 2, 2 resimden 1. Motorola i850 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Completely remove the outer casing from the phone.
  8. Motorola i850 LCD Screen Replacement: adım 8, 2 resimden 1. Motorola i850 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 LCD Screen Replacement: adım 10, 1 resimden 1.
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 LCD Screen Replacement: adım 11, 2 resimden 1. Motorola i850 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 LCD Screen Replacement, LCD Screen: adım 12, 1 resimden 1.
    • Firmly detach the gold strip using a Tweezer.
  13. Motorola i850 LCD Screen Replacement: adım 13, 1 resimden 1.
    • Prop out the LCD screen using a Small Flathead Screwdriver.
  14. Motorola i850 LCD Screen Replacement: adım 14, 3 resimden 1. Motorola i850 LCD Screen Replacement: adım 14, 3 resimden 2. Motorola i850 LCD Screen Replacement: adım 14, 3 resimden 3.
    • Remove the LCD screen from the LCD board.
Sonuç
Andrew Aw
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 34-56, Forte Spring 2010 Cal Poly, Team 34-56, Forte Spring 2010 üyesi
CPSU-FORTE-S10S34G56
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 2,189
