Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Open the flip cover of the phone with the LCD screen facing towards you.
Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
Partially close the flip cover of the phone in order to take off the outer case.
Place your thumb underneath the protective metal covering to remove it from the phone.
Gently detach the black microchip from the phone with a Tweezer.
Prop out the LCD board from the phone using your fingertips.
Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
Prop out the LCD screen using a Small Flathead Screwdriver.
