Ana içeriğe geç
Motorola i886 Slide-out Keyboard Replacement
Neye ihtiyacın var
    1. Motorola i886 Slide-out Keyboard Replacement, Back Cover: adım 1, 2 resimden 1. Motorola i886 Slide-out Keyboard Replacement, Back Cover: adım 1, 2 resimden 2.
      • Undo the headphone jack and USB port cover with your fingertip. Place your middle finger in the indent on the upper left side of the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola i886 Slide-out Keyboard Replacement, Open: adım 2, 1 resimden 1.
      • Pull back until cover is removed. Place cover aside.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola i886 Slide-out Keyboard Replacement, Battery: adım 3, 1 resimden 1.
      • Locate battery and use your index finger to grasp the upper left side of the battery and pull back to remove. Set battery aside.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola i886 Slide-out Keyboard Replacement, SIM Card: adım 4, 1 resimden 1.
      • Locate and use your thumb to slide the SIM card to the right until it is removed and set it aside.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola i886 Slide-out Keyboard Replacement, Screw Removal: adım 5, 2 resimden 1. Motorola i886 Slide-out Keyboard Replacement, Screw Removal: adım 5, 2 resimden 2.
      • Remove eight black .4 centimeter screws on the top, bottom, and sides of the phone with a T5 Torx screwdriver by inserting it into the screws and turning it to the left. Set screws aside.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola i886 Slide-out Keyboard Replacement, Separating: adım 6, 1 resimden 1.
      • Loosen four fastener pieces on the side and bottom with a plastic opening tool to pry them backwards.
      • Insert the plastic opening tool between the loosened casing and the rest of the phone and pry the two pieces apart to remove the casing.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola i886 Slide-out Keyboard Replacement: adım 7, 1 resimden 1.
      • Remove the .3 centimeter silver screw with the T5 Torx screwdriver.
      • Use your fingertips to lift up the circuit board and lay it on the side of the phone. Note that the two pieces are attached by a gold and black strip.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola i886 Slide-out Keyboard Replacement, Keyboard Removal: adım 8, 1 resimden 1.
      • Locate and grip the black, white, and blue keyboard layer with your fingernail, lift up to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Felicita Correa
418 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 486
