Ana içeriğe geç
Motorola i90c speaker replacement
Neye ihtiyacın var
  1. Motorola i90c speaker replacement, Battery: adım 1, 3 resimden 1. Motorola i90c speaker replacement, Battery: adım 1, 3 resimden 2. Motorola i90c speaker replacement, Battery: adım 1, 3 resimden 3.
    • Slide the notch downward while pulling the back cover off to remove it.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola i90c speaker replacement: adım 2, 3 resimden 1. Motorola i90c speaker replacement: adım 2, 3 resimden 2. Motorola i90c speaker replacement: adım 2, 3 resimden 3.
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola i90c speaker replacement, Antenna: adım 3, 2 resimden 1. Motorola i90c speaker replacement, Antenna: adım 3, 2 resimden 2.
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola i90c speaker replacement, Midframe: adım 4, 3 resimden 1. Motorola i90c speaker replacement, Midframe: adım 4, 3 resimden 2. Motorola i90c speaker replacement, Midframe: adım 4, 3 resimden 3.
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola i90c speaker replacement: adım 5, 2 resimden 1. Motorola i90c speaker replacement: adım 5, 2 resimden 2.
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola i90c speaker replacement: adım 6, 3 resimden 1. Motorola i90c speaker replacement: adım 6, 3 resimden 2. Motorola i90c speaker replacement: adım 6, 3 resimden 3.
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola i90c speaker replacement, Speaker System: adım 7, 3 resimden 1. Motorola i90c speaker replacement, Speaker System: adım 7, 3 resimden 2. Motorola i90c speaker replacement, Speaker System: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the prying tools to wedge out the circular part of the speaker system.
    • Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jorge
4 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-61, Johann Spring 2010 Cal Poly, Team 29-61, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G61
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 1,475
