Ana içeriğe geç
Mountain Bike Brake Lever Replacement
Neye ihtiyacın var
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: adım 1, 2 resimden 1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: adım 1, 2 resimden 2.
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: adım 2, 2 resimden 1. Mountain Bike Brake Lever Replacement: adım 2, 2 resimden 2.
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: adım 3, 1 resimden 1.
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: adım 4, 2 resimden 1. Mountain Bike Brake Lever Replacement: adım 4, 2 resimden 2.
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: adım 5, 1 resimden 1.
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: adım 6, 3 resimden 1. Mountain Bike Brake Lever Replacement: adım 6, 3 resimden 2. Mountain Bike Brake Lever Replacement: adım 6, 3 resimden 3.
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: adım 7, 3 resimden 1. Mountain Bike Brake Lever Replacement: adım 7, 3 resimden 2. Mountain Bike Brake Lever Replacement: adım 7, 3 resimden 3.
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
Sonuç
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 56
Her zaman: 4,257
