Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a 5mm allen key, loosen the lever assembly from the handle.
Slide the assembly off of the handle.
Take your new lever assembly and slide it onto the handle; leave it loose.
Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
Line up your lever assembly back into place.
Tighten the screw with the allen key to secure it.
Install the brake cable into the lever housing.
Take the brake cable and feed it into the lever pull.
Feed the cable into the lever assembly slot and through the barrel adjuster.
Use the barrel adjuster to tighten the cable intro place.
Bir başkası bu kılavuzu tamamladı.
