Ana içeriğe geç
Mounting and dismounting the tablet
Neye ihtiyacın var
  1. Mounting and dismounting the tablet, Mounting and dismounting the tablet: adım 1, 1 resimden 1.
    • The hull seen from the front.
    FixBot'a Sor
    Yorum Ekle
  2. Mounting and dismounting the tablet: adım 2, 1 resimden 1.
    • The case seen from the back, with the jacks where to connect your handsets
    FixBot'a Sor
    Yorum Ekle
  3. Mounting and dismounting the tablet: adım 3, 1 resimden 1.
    • Enough to redo a shell in case of problems, but without the feet.
    • The T14 snake-eyes tip to disassemble the facade.
    • Collars to block the jacks of your handsets under the shell.
    • Replacement snake eyes M6 screws, M6 inserts to remake a shell
    FixBot'a Sor
    Yorum Ekle
  4. Mounting and dismounting the tablet: adım 4, 1 resimden 1.
    • Use the tip to disassemble the screws.
    • DO IT MANUALLY!!!
    • Not to the screwdriver, because it will rip. And the tip will damage the facade.
    FixBot'a Sor
    Yorum Ekle
  5. Mounting and dismounting the tablet: adım 5, 1 resimden 1.
    • To block the jacks of the handsets: make a knot on the collar.
    • Thus, users will not be able to disconnect the handsets
    FixBot'a Sor
    Yorum Ekle
  6. Mounting and dismounting the tablet: adım 6, 1 resimden 1.
    • If you want to redo a shell:
    • You have to cut the inserts, and pierce the bottom to pass the usb plug and the jack that connects to the tablet.
    • Take the model delivered as an example
    FixBot'a Sor
    Yorum Ekle
  7. Mounting and dismounting the tablet: adım 7, 1 resimden 1.
    • To change the content of the micro SD card:
    • You must disassemble the facade, remove the tablet from the shell and open the "SD card" hatch
    • Create a file named: sexbreizh.avi
    • AVI container, mp3 audio codec, xvid video codec
    • Audio bitrate: 44100
    • Video rate: 8000
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
AFPD Conception
244 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 35
Son 30 gün: 146
Her zaman: 2,552
