Ana içeriğe geç
Mpow MPBH063 Battery Replacement
Neye ihtiyacın var
  1. Mpow MPBH063 Battery Replacement, Battery: adım 1, 3 resimden 1. Mpow MPBH063 Battery Replacement, Battery: adım 1, 3 resimden 2. Mpow MPBH063 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Mpow MPBH063 Battery Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
    FixBot'a Sor
    Yorum Ekle
  3. Mpow MPBH063 Battery Replacement: adım 3, 1 resimden 1.
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Mpow MPBH063 Battery Replacement: adım 4, 1 resimden 1.
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
Lianna Cook
272 İtibar
2 adet Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
Where can I find a replacement battery for this speaker?
Sean DuBois - Yanıt Paylaş
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 4,781
