Ana içeriğe geç
Mr. Coffee DW13 Base Removal
Neye ihtiyacın var
  1. Mr. Coffee DW13 Base Removal, Base: adım 1, 2 resimden 1. Mr. Coffee DW13 Base Removal, Base: adım 1, 2 resimden 2.
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Base Removal: adım 2, 2 resimden 1. Mr. Coffee DW13 Base Removal: adım 2, 2 resimden 2.
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Base Removal: adım 3, 1 resimden 1.
    • Gently lift the base cover to expose the inside of the coffee machine.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tess Bradley
373 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G31
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 3,106
