Giriş
In order to remove the base of your Mr. Coffee DW13, you will need to position the coffee machine so that the bottom is facing you. After, you will remove eight screws and gently lift the cover from the base.
Neye ihtiyacın var
Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
Bir başkası bu kılavuzu tamamladı.
