Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This is an easy replacement. All you need to do is open the top of the coffeemaker, move a black plastic arm, and lift the filter out of the machine.
  1. Face the top of the coffeemaker towards you.
    • Face the top of the coffeemaker towards you.
  2. Identify the two tabs on top of the machine. Lift the top of the coffeemaker up, using these tabs
    • Identify the two tabs on top of the machine.
    • Lift the top of the coffeemaker up, using these tabs
  3. Slide the black spout towards the back of the coffee maker, exposing the filter. Slide the black spout towards the back of the coffee maker, exposing the filter. Slide the black spout towards the back of the coffee maker, exposing the filter.
    • Slide the black spout towards the back of the coffee maker, exposing the filter.
  4. Using the side tabs, gently lift the filter up and out of the machine. Using the side tabs, gently lift the filter up and out of the machine.
    • Using the side tabs, gently lift the filter up and out of the machine.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tess Bradley
346 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G31
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 534
