Giriş
To complete this repair, you will need a Philip's Head screwdriver. You will remove the base of the coffeemaker, unscrew a tab holding the power cord in place, and detach the power cord electrical connectors from the interior power switch. Then, all you have to do is pull the power cord out from the machine!
Neye ihtiyacın var
Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
3 farklı kişi bu kılavuzu tamamladı.
