Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The bottom cover must be removed prior to replacing or repairing any internal parts of the Mr. Coffee TF6 (hot plate, power cord, and water tubes). In the event that the bottom cover breaks or must be replaced, a replacement cover must by obtained from the manufacturer.
Parçalar
Hiçbir parça belirtilmedi.
  1. Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place. Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Gently lift the bottom cover, detaching it from the main body of the TF6.
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
Sonuç
Johnny Romeka
201 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G18
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 388
