Ana içeriğe geç
Mr. Coffee TF6 Dust Cover Replacement
Neye ihtiyacın var
    1. Mr. Coffee TF6 Dust Cover Replacement, Dust Cover: adım 1, 2 resimden 1. Mr. Coffee TF6 Dust Cover Replacement, Dust Cover: adım 1, 2 resimden 2.
      • Facing the front of the TF6, gently lift the dust cover along its hinge until it reaches its designed stopping point.
      FixBot'a Sor
      Yorum Ekle
    2. Mr. Coffee TF6 Dust Cover Replacement: adım 2, 2 resimden 1. Mr. Coffee TF6 Dust Cover Replacement: adım 2, 2 resimden 2.
      • Orient the retaining bracket upwards (away from the main body of unit).
      • Do not push the retaining bracket beyond its designed range of motion. It may snap if too much force is applied outside its limit.
      FixBot'a Sor
      Yorum Ekle
    3. Mr. Coffee TF6 Dust Cover Replacement: adım 3, 1 resimden 1.
      • With the retaining clip in its released position, pull the spout down towards the filter basket.
      FixBot'a Sor
      Yorum Ekle
    4. Mr. Coffee TF6 Dust Cover Replacement: adım 4, 2 resimden 1. Mr. Coffee TF6 Dust Cover Replacement: adım 4, 2 resimden 2.
      • Carefully detach the dust cover by disengaging the locking pins, starting at one side.
      • Extra force may be required to disengage the dust cover's locking pins. Refrain from applying excessive upward force on the dust cover, as dong so may cause the pins to snap under pressure.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Follow these steps in reverse order with a new Dust Cover.
Jordan
204 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G18
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 730
