Ana içeriğe geç
Mt. Fury Roadmaster Brake Pad Replacement
Neye ihtiyacın var
    1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: adım 1, 2 resimden 1. Mt. Fury Roadmaster Brake Pad Replacement, Brake Pad: adım 1, 2 resimden 2.
      • Locate and remove the dome nut with a 10mm open-end wrench.
      FixBot'a Sor
      Yorum Ekle
    2. Mt. Fury Roadmaster Brake Pad Replacement: adım 2, 1 resimden 1.
      • Inspect brake pad for wear.
      FixBot'a Sor
      Yorum Ekle
    3. Mt. Fury Roadmaster Brake Pad Replacement: adım 3, 1 resimden 1.
      • Dome nut (left), lock washer (middle), and brake pad (right).
      • Be sure to save the dome nut and lock washer just in case the replacement brake shoe does not include them.
      FixBot'a Sor
      Yorum Ekle
      • When installing the new brake shoe, make sure it is properly aligned so it is in full contact with the edge of the rim.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To install your new brake shoes, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Monty Dodge Jr
669 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 üyesi
CPSU-MANESS-W14S1G40
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 32
Her zaman: 2,505
