Ana içeriğe geç
Munchkinz Battery Replacement
Neye ihtiyacın var
    1. Munchkinz Battery Replacement, Opening Device: adım 1, 1 resimden 1.
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Battery Replacement, Pry Device Apart: adım 2, 2 resimden 1. Munchkinz Battery Replacement, Pry Device Apart: adım 2, 2 resimden 2.
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      FixBot'a Sor
      Yorum Ekle
    3. Munchkinz Battery Replacement, Separated Device: adım 3, 1 resimden 1.
      • After prying the device apart, it should look like this.
      FixBot'a Sor
      Yorum Ekle
    1. Munchkinz Battery Replacement, Removing battery: adım 4, 3 resimden 1. Munchkinz Battery Replacement, Removing battery: adım 4, 3 resimden 2. Munchkinz Battery Replacement, Removing battery: adım 4, 3 resimden 3.
      • Use the wide plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Battery Replacement, Remove battery completely: adım 5, 1 resimden 1.
      • Use the Soldering Iron to disconnect the each cable.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Hee Jin Cho
113 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G6
3 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 754
