Ana içeriğe geç
Munchkinz External Casing Removal
Neye ihtiyacın var
  1. Munchkinz External Casing Removal, Opening Device: adım 1, 1 resimden 1.
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz External Casing Removal, Pry Device Apart: adım 2, 2 resimden 1. Munchkinz External Casing Removal, Pry Device Apart: adım 2, 2 resimden 2.
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz External Casing Removal, Separated Device: adım 3, 1 resimden 1.
    • After prying the device apart, it should look like this.
Sonuç
Austin Oliveira
204 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G6
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 220
