Ana içeriğe geç
Munchkinz LCD Assembly
Neye ihtiyacın var
  1. Munchkinz LCD Assembly, Opening Device: adım 1, 1 resimden 1.
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: adım 2, 2 resimden 1. Munchkinz LCD Assembly, Pry Device Apart: adım 2, 2 resimden 2.
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: adım 3, 1 resimden 1.
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: adım 4, 1 resimden 1.
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: adım 5, 1 resimden 1.
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: adım 6, 2 resimden 1. Munchkinz LCD Assembly, Unscrew Volume Module: adım 6, 2 resimden 2.
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: adım 7, 1 resimden 1.
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: adım 8, 1 resimden 1.
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: adım 9, 1 resimden 1.
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: adım 10, 1 resimden 1.
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: adım 11, 1 resimden 1.
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: adım 12, 3 resimden 1. Munchkinz LCD Assembly, Pry Up Screen: adım 12, 3 resimden 2. Munchkinz LCD Assembly, Pry Up Screen: adım 12, 3 resimden 3.
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: adım 13, 1 resimden 1.
    • Unsolder the black and red LCD wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David Wood
440 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G6
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 338
