Ana içeriğe geç
Munchkinz Speaker Replacement
Neye ihtiyacın var
    1. Munchkinz Speaker Replacement, Opening Device: adım 1, 1 resimden 1.
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Speaker Replacement, Pry Device Apart: adım 2, 2 resimden 1. Munchkinz Speaker Replacement, Pry Device Apart: adım 2, 2 resimden 2.
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      FixBot'a Sor
      Yorum Ekle
    3. Munchkinz Speaker Replacement, Separated Device: adım 3, 1 resimden 1.
      • After prying the device apart, it should look like this.
      FixBot'a Sor
      Yorum Ekle
    1. Munchkinz Speaker Replacement, Pry Speaker: adım 4, 2 resimden 1. Munchkinz Speaker Replacement, Pry Speaker: adım 4, 2 resimden 2.
      • Use the slim plastic opening tool to remove the speaker from its position on the case.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Speaker Replacement, Locate Wires: adım 5, 1 resimden 1.
      • Locate the red and black wires that connect the speaker to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Munchkinz Speaker Replacement, Solder Wires: adım 6, 1 resimden 1.
      • Un-solder the red and black speaker wires that are connected to the motherboard
      FixBot'a Sor
      Yorum Ekle
Sonuç
David Wood
440 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G6
3 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 415
