Ana içeriğe geç
Munchkinz Volume Button assembly
Neye ihtiyacın var
    1. Munchkinz Volume Button assembly, Opening Device: adım 1, 1 resimden 1.
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Volume Button assembly, Pry Device Apart: adım 2, 2 resimden 1. Munchkinz Volume Button assembly, Pry Device Apart: adım 2, 2 resimden 2.
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      FixBot'a Sor
      Yorum Ekle
    3. Munchkinz Volume Button assembly, Separated Device: adım 3, 1 resimden 1.
      • After prying the device apart, it should look like this.
      FixBot'a Sor
      Yorum Ekle
    1. Munchkinz Volume Button assembly, Pry Camera: adım 4, 1 resimden 1.
      • Use the slim plastic opening tool to pry the camera from its initial position.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Volume Button assembly, Disconnect Ribbon: adım 5, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Munchkinz Volume Button assembly, Volume Button: adım 6, 1 resimden 1.
      • Remove the plastic volume button.
      FixBot'a Sor
      Yorum Ekle
    2. Munchkinz Volume Button assembly, Unscrew Module: adım 7, 1 resimden 1.
      • Remove the two screws that hold the volume button assembly in place.
      FixBot'a Sor
      Yorum Ekle
    3. Munchkinz Volume Button assembly, Solder Module Wires: adım 8, 1 resimden 1.
      • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
David Wood
440 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 üyesi
UWT-ROSE-W15S3G6
3 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 531
