Ana içeriğe geç
MusicAngel JH-MD04E2 wired speakers Disassembly
Neye ihtiyacın var
  1. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: adım 1, 3 resimden 1. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: adım 1, 3 resimden 2. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: adım 1, 3 resimden 3.
    • Bottom side has 4 5.95mm tapping Phillips #1 screws, under a rubber cover.
    • Under the label, there are two more Phillips #1 screws 9.15mm tapping screws.
  2. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: adım 2, 3 resimden 1. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: adım 2, 3 resimden 2. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: adım 2, 3 resimden 3.
    • Use a very thin metal prying tool and slide it in between the metal looking grill and the speaker body. Carefully pry it out (no glue is used) all the way around.
    • Repeat on both speaker sides.
  3. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: adım 3, 3 resimden 1. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: adım 3, 3 resimden 2. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: adım 3, 3 resimden 3.
    • Use a spudger to pry the battery that is glued to the top, from the body. Note: This is pretty strong adhesive.
    • Tilt the speaker grill / element a little, to slide it through the body.
  4. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: adım 4, 3 resimden 1. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: adım 4, 3 resimden 2. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: adım 4, 3 resimden 3.
    • As you can see, there are no connectors used. All connections are soldered directly to the board.
    • No information can be found on the battery, either side.
    • The speaker elements are 45mm, 3W and 4Ω
  5. MusicAngel JH-MD04E2 wired speakers Disassembly, Board overview: adım 5, 1 resimden 1.
    • Not really much going on on this board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Geir Ove Andersen
8.022 İtibar
5 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 329
