Ana içeriğe geç
N-Strike Nite Finder EX-3 Battery Replacement
Neye ihtiyacın var
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: adım 2, 1 resimden 1.
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
Sonuç
Nicholas Samokyszyn
359 İtibar
3 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-8, Lauer Spring 2014 Michigan Tech, Team 5-8, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G8
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 2,661
