Ana içeriğe geç
NABI XD Battery Replacement
Neye ihtiyacın var
  1. NABI XD Battery Replacement, Rear panel: adım 1, 2 resimden 1. NABI XD Battery Replacement, Rear panel: adım 1, 2 resimden 2.
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Battery Replacement: adım 2, 1 resimden 1.
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Battery Replacement, Battery: adım 3, 2 resimden 1. NABI XD Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Battery Replacement: adım 4, 1 resimden 1.
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
Sonuç
Marissa Schiereck
638 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G2
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Where can you get the battery?
Dave - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 782
