Ana içeriğe geç
NABI XD Charging port Replacement
Neye ihtiyacın var
    1. NABI XD Charging port Replacement, Rear panel: adım 1, 2 resimden 1. NABI XD Charging port Replacement, Rear panel: adım 1, 2 resimden 2.
      • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
      FixBot'a Sor
      Yorum Ekle
    2. NABI XD Charging port Replacement: adım 2, 1 resimden 1.
      • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
      • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
      • Go around the NABI XD and separate the rear panel from the device.
      FixBot'a Sor
      Yorum Ekle
    1. NABI XD Charging port Replacement, Battery: adım 3, 2 resimden 1. NABI XD Charging port Replacement, Battery: adım 3, 2 resimden 2.
      • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
      FixBot'a Sor
      Yorum Ekle
    2. NABI XD Charging port Replacement: adım 4, 1 resimden 1.
      • Battery is glued to the base, lift carefully.
      • To remove battery, lift the battery up from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. NABI XD Charging port Replacement, Charging port: adım 5, 2 resimden 1. NABI XD Charging port Replacement, Charging port: adım 5, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
      • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
      FixBot'a Sor
      Yorum Ekle
    2. NABI XD Charging port Replacement: adım 6, 1 resimden 1.
      • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
      • Lift the charging port from the NABI XD.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Marissa Schiereck
638 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 35
Her zaman: 952
