Giriş
This guide should be used when replacing the motherboard or other components. Has the NABI XD taken water damaged or won't turn on after troubleshooting the charger. Then, replacing the motherboard will fix you device.
Neye ihtiyacın var
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Remove the two 4mm Phillips screws with the PH#0 screwdriver.
Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
