Ana içeriğe geç
NERF Doomlands 2169 Lawbringer Blaster Catch Spring Replacement
Neye ihtiyacın var
  1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: adım 1, 2 resimden 1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: adım 1, 2 resimden 2.
    • Locate and remove all 14 screws of the outer case and gently remove it avoiding any damage.
  2. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 2, 1 resimden 1.
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out.
  3. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 3, 1 resimden 1.
    • Remove the exterior spring from the sliding mechanism and re-position the gun on its opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 4, 1 resimden 1.
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 5, 1 resimden 1.
    • Remove the spring and trigger mechanism from the gun, and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 6, 1 resimden 1.
    • This is where the spring load mechanism is located, be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
    • Carefully slide out the big spring and fit in your replacement (thin-coil end coiled around the orange plastic)
  7. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 7, 1 resimden 1.
    • A second set of hands would be useful during this step. Make sure the orange slide is above the spring.
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
  8. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 8, 1 resimden 1.
    • Reconnect the spring to the orange slider, and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 9, 2 resimden 1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 9, 2 resimden 2.
    • Slide the orange supporting piece into the crevice below the air chamber.
    • Slide the rotating cartridge back into place
  10. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 10, 2 resimden 1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: adım 10, 2 resimden 2.
    • Look to the beginning of this guide for help to reassemble this gun.
    • Carefully reassemble the Nerf Law bringer in the same order you took it apart. Carefully reattach the 3 screws that seal the air chamber.
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Perriello
134 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 1,890
