Ana içeriğe geç
NERF Doomlands 2169 Lawbringer Blaster Spring Replacement
Neye ihtiyacın var
  1. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: adım 1, 2 resimden 1. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: adım 1, 2 resimden 2.
    • Remove sixteen screws from the outer case.
    • Remove the outer case from the rest of the device.
  2. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 2, 1 resimden 1.
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Potential for device damage: Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out!
  3. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 3, 1 resimden 1.
    • Remove the exterior spring from the sliding mechanism and rotate the gun to the opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 4, 2 resimden 1. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 4, 2 resimden 2.
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 5, 1 resimden 1.
    • Remove the spring and trigger mechanism from the gun and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 6, 1 resimden 1.
    • Carefully slide out the big spring and fit in your replacement (the thin-coil end is coiled around the orange plastic).
    • Potential for device damage: This is where the spring load mechanism is located. Be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
  7. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 7, 1 resimden 1.
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
    • Make sure the orange slide is above the spring. A second set of hands would be useful during this step.
  8. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 8, 1 resimden 1.
    • Reconnect the spring to the orange slider and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 9, 1 resimden 1.
    • Slide the orange supporting piece into the crevice below the air chamber.
  10. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 10, 1 resimden 1.
    • Slide the rotating cartridge back into place.
  11. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 11, 1 resimden 1.
    • Carefully reassemble the NERF Lawbringer in the same order you took it apart. Carefully reattach the three screws that seal the air chamber.
  12. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: adım 12, 1 resimden 1.
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
Bitiş Çizgisi
Georgia Slack
113 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 971
