Ana içeriğe geç
NETGEAR WGT624 v3 Lower Case Replacement
Neye ihtiyacın var
  1. NETGEAR WGT624 v3 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Lower Case Replacement: adım 2, 3 resimden 1. NETGEAR WGT624 v3 Lower Case Replacement: adım 2, 3 resimden 2. NETGEAR WGT624 v3 Lower Case Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Lower Case Replacement: adım 3, 2 resimden 1. NETGEAR WGT624 v3 Lower Case Replacement: adım 3, 2 resimden 2.
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Lower Case Replacement: adım 4, 2 resimden 1. NETGEAR WGT624 v3 Lower Case Replacement: adım 4, 2 resimden 2.
    • Lift the lower case straight up from the rest of the router.
Sonuç
Nicole Slagle
83 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-31, Amido Winter 2013 Cal Poly, Team 3-31, Amido Winter 2013 üyesi
CPSU-AMIDO-W13S3G31
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 458
