Ana içeriğe geç
NIkon Coolpix A900 I/O Cover Replacement
Neye ihtiyacın var
  1. NIkon Coolpix A900 I/O Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. NIkon Coolpix A900 I/O Cover Replacement: adım 2, 2 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 2, 2 resimden 2.
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. NIkon Coolpix A900 I/O Cover Replacement: adım 3, 2 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 3, 2 resimden 2.
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. NIkon Coolpix A900 I/O Cover Replacement, Rear Case: adım 4, 3 resimden 1. NIkon Coolpix A900 I/O Cover Replacement, Rear Case: adım 4, 3 resimden 2. NIkon Coolpix A900 I/O Cover Replacement, Rear Case: adım 4, 3 resimden 3.
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. NIkon Coolpix A900 I/O Cover Replacement: adım 5, 3 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 5, 3 resimden 2. NIkon Coolpix A900 I/O Cover Replacement: adım 5, 3 resimden 3.
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. NIkon Coolpix A900 I/O Cover Replacement: adım 6, 3 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 6, 3 resimden 2. NIkon Coolpix A900 I/O Cover Replacement: adım 6, 3 resimden 3.
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. NIkon Coolpix A900 I/O Cover Replacement: adım 7, 2 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 7, 2 resimden 2.
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. NIkon Coolpix A900 I/O Cover Replacement: adım 8, 2 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 8, 2 resimden 2.
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. NIkon Coolpix A900 I/O Cover Replacement: adım 9, 3 resimden 1. NIkon Coolpix A900 I/O Cover Replacement: adım 9, 3 resimden 2. NIkon Coolpix A900 I/O Cover Replacement: adım 9, 3 resimden 3.
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: adım 10, 3 resimden 1. NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: adım 10, 3 resimden 2. NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: adım 10, 3 resimden 3.
    • Locate the I/O cover on the rear case.
    • On the inside of the case, unhook the I/O cover by lifting up.
    • You may not need the spudger to remove the cover.
  11. NIkon Coolpix A900 I/O Cover Replacement: adım 11, 1 resimden 1.
    • Remove the I/O cover by gently pulling away from the rear case.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 428
