Ana içeriğe geç
NIkon Coolpix A900 Lens Replacement
Neye ihtiyacın var
  1. NIkon Coolpix A900 Lens Replacement, Battery: adım 1, 1 resimden 1.
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. NIkon Coolpix A900 Lens Replacement: adım 2, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 2, 2 resimden 2.
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. NIkon Coolpix A900 Lens Replacement: adım 3, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 3, 2 resimden 2.
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. NIkon Coolpix A900 Lens Replacement, Rear Case: adım 4, 3 resimden 1. NIkon Coolpix A900 Lens Replacement, Rear Case: adım 4, 3 resimden 2. NIkon Coolpix A900 Lens Replacement, Rear Case: adım 4, 3 resimden 3.
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. NIkon Coolpix A900 Lens Replacement: adım 5, 3 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 5, 3 resimden 2. NIkon Coolpix A900 Lens Replacement: adım 5, 3 resimden 3.
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. NIkon Coolpix A900 Lens Replacement: adım 6, 3 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 6, 3 resimden 2. NIkon Coolpix A900 Lens Replacement: adım 6, 3 resimden 3.
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. NIkon Coolpix A900 Lens Replacement: adım 7, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 7, 2 resimden 2.
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. NIkon Coolpix A900 Lens Replacement: adım 8, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 8, 2 resimden 2.
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. NIkon Coolpix A900 Lens Replacement: adım 9, 3 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 9, 3 resimden 2. NIkon Coolpix A900 Lens Replacement: adım 9, 3 resimden 3.
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. NIkon Coolpix A900 Lens Replacement, Lens: adım 10, 3 resimden 1. NIkon Coolpix A900 Lens Replacement, Lens: adım 10, 3 resimden 2. NIkon Coolpix A900 Lens Replacement, Lens: adım 10, 3 resimden 3.
    • Place the camera in front of you with the lens facing down.
    • On the top right, remove the 4.5 mm Phillips #00 screw holding the input shield.
  11. NIkon Coolpix A900 Lens Replacement: adım 11, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 11, 2 resimden 2.
    • Remove the 4.5 mm Phillips #00 screw holding the bracket in the bottom right.
    • Remove the 2.5 mm Phillips #00 rear brace screw.
  12. NIkon Coolpix A900 Lens Replacement: adım 12, 3 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 12, 3 resimden 2. NIkon Coolpix A900 Lens Replacement: adım 12, 3 resimden 3.
    • Use your finger to undo the ribbon connector on the top right of the camera.
    • Remove the two 2.5mm Phillips #00 screws holding the small chip in place. Remove the small chip.
    • Remove the final two 4.5 mm Phillips #00 screws from the left side of the brace.
  13. NIkon Coolpix A900 Lens Replacement: adım 13, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 13, 2 resimden 2.
    • Gently lift the rear brace off of the camera.
  14. NIkon Coolpix A900 Lens Replacement: adım 14, 2 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 14, 2 resimden 2.
    • Use your finger to undo the three ribbon connectors.
    • Make sure that all ribbons are properly disconnected before proceeding.
  15. NIkon Coolpix A900 Lens Replacement: adım 15, 3 resimden 1. NIkon Coolpix A900 Lens Replacement: adım 15, 3 resimden 2. NIkon Coolpix A900 Lens Replacement: adım 15, 3 resimden 3.
    • Carefully lift the lens out of the camera.
    • It may be necessary to gently pry these tabs out of the way to release the lens.
    • When reassembling, make sure that the ribbon cables are flat against the lens to ensure that they don't snag.
  16. NIkon Coolpix A900 Lens Replacement: adım 16, 1 resimden 1.
    • Separate the lens from the body of the camera.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
2 Yorum
How to replace the front-lens of the zoom-lens, when it’s scratched!?!
Tom de Hoop - Yanıt
Ok I removed the defective one, but my question now is: what model of lens can I replace it with? Is it compatible with any lens from Nikon, or from other manufacturers?
martin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 72
Her zaman: 3,531
