Giriş
This guide will help you remove the kettle pot from the inside of the popcorn maker. In order to begin the procedure, make sure the machine is unplugged and has been turned off for at least one hour to ensure the kettle pot is not hot. Lay the popcorn maker on its side before beginning.
  1. Unplug the machine and tilt the machine on its side with the door facing up. Open the door.
    • Unplug the machine and tilt the machine on its side with the door facing up.
    • Open the door.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Reach in and lift the kettle pot up and towards you to pull it out of the popcorn machine. Reach in and lift the kettle pot up and towards you to pull it out of the popcorn machine.
    • Reach in and lift the kettle pot up and towards you to pull it out of the popcorn machine.
  4. Unplug the plug from the kettle pot to remove it from the machine. Unplug the plug from the kettle pot to remove it from the machine.
    • Unplug the plug from the kettle pot to remove it from the machine.
Sonuç
anhua@ucdavis.edu
281 İtibar
2 adet Kılavuz yazıldı
Takım
UC Davis, Team S4-G4, Lore Fall 2018 UC Davis, Team S4-G4, Lore Fall 2018 üyesi
UCD-LORE-F18S4G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 41
