Giriş
This guide will help you remove the kettle pot from the inside of the popcorn maker. In order to begin the procedure, make sure the machine is unplugged and has been turned off for at least one hour to ensure the kettle pot is not hot. Lay the popcorn maker on its side before beginning.
Unplug the machine and tilt the machine on its side with the door facing up.
Open the door.
Bir başkası bu kılavuzu tamamladı.
