Ana içeriğe geç
NP-R540-JA09US Keyboard Replacement
Neye ihtiyacın var
  1. NP-R540-JA09US Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. NP-R540-JA09US Keyboard Replacement: adım 2, 1 resimden 1.
    • Pull the two latches outward.
    FixBot'a Sor
    Yorum Ekle
  3. NP-R540-JA09US Keyboard Replacement: adım 3, 2 resimden 1. NP-R540-JA09US Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the battery out of the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. NP-R540-JA09US Keyboard Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Remove securing screw with the PH0 head.
    FixBot'a Sor
    Yorum Ekle
  5. NP-R540-JA09US Keyboard Replacement: adım 5, 1 resimden 1.
    • Slide the optical drive out and remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  6. NP-R540-JA09US Keyboard Replacement, Keyboard: adım 6, 1 resimden 1.
    • Remove the two Phillips #0 screws labeled KBD.
    FixBot'a Sor
    Yorum Ekle
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
    FixBot'a Sor
    Yorum Ekle
  7. NP-R540-JA09US Keyboard Replacement: adım 8, 1 resimden 1.
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
    FixBot'a Sor
    Yorum Ekle
  8. NP-R540-JA09US Keyboard Replacement: adım 9, 2 resimden 1. NP-R540-JA09US Keyboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the keyboard cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 1,350
