Ana içeriğe geç
NVIDIA SHIELD Portable Motherboard Replacement
Neye ihtiyacın var
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: adım 1, 3 resimden 1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: adım 1, 3 resimden 2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: adım 1, 3 resimden 3.
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: adım 2, 2 resimden 1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: adım 2, 2 resimden 2.
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: adım 3, 3 resimden 1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: adım 3, 3 resimden 2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: adım 3, 3 resimden 3.
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: adım 4, 1 resimden 1.
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: adım 5, 3 resimden 1. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: adım 5, 3 resimden 2. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: adım 5, 3 resimden 3.
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: adım 6, 3 resimden 1. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: adım 6, 3 resimden 2. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: adım 6, 3 resimden 3.
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Marc Perez
545 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G1
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 12
Her zaman: 1,812
