Ana içeriğe geç
Nabi 2 Screen Replacement
Neye ihtiyacın var
  1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 2. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: adım 1, 3 resimden 3.
    • Remove the rubber bumper from the tablet.
    FixBot'a Sor
    Yorum Ekle
  2. Nabi 2  Screen Replacement: adım 2, 2 resimden 1. Nabi 2  Screen Replacement: adım 2, 2 resimden 2.
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
    FixBot'a Sor
    Yorum Ekle
  3. Nabi 2  Screen Replacement: adım 3, 3 resimden 1. Nabi 2  Screen Replacement: adım 3, 3 resimden 2. Nabi 2  Screen Replacement: adım 3, 3 resimden 3.
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
    FixBot'a Sor
    Yorum Ekle
  4. Nabi 2  Screen Replacement, Screen: adım 4, 3 resimden 1. Nabi 2  Screen Replacement, Screen: adım 4, 3 resimden 2. Nabi 2  Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
    FixBot'a Sor
    Yorum Ekle
  5. Nabi 2  Screen Replacement: adım 5, 3 resimden 1. Nabi 2  Screen Replacement: adım 5, 3 resimden 2. Nabi 2  Screen Replacement: adım 5, 3 resimden 3.
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
    FixBot'a Sor
    Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Michelle
899 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-3, Lacy Spring 2016 USF Tampa, Team 4-3, Lacy Spring 2016 üyesi
USFT-LACY-S16S4G3
4 Üyeler
14 adet Kılavuz yazıldı
4Kılavuz Yorumları
Simple steps but very practical
myjamro - Yanıt Paylaş
Is the LCD glued to the front glass/digitizer?
Brent Huff - Yanıt Paylaş
It Worked Thank U So Much!!!
Sharon Thrash - Yanıt Paylaş
a piece that holds the screen ribbon cable in broke off my nabis motherboard while taking the screen off. I eventually did get the screen back on.
NabiGuy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 8,529
